JBR, I wouldn't have thought that when God created universe and all life within it, that he could further interfere in its make up, hence why he would not come down to earth himself and sort out all our problems, he gave us the brains to do it for ourselves, that was his plan obviously, just as you would design a boiler, device a gas valve that would be 5th generation gas valve designed by a bloke called dan Robinson, using a pentium based processor to give a precise amount of gas required to burn exactly according to the amount of oxygen present in the combustion chamber, and according to the hot water demand, emitting zero co and little unburnt products, and poor dan can't do sod all when things go wrong with the processor, it freezes with a bug, and the 5th Generation Gas valve is condemned as very unsafe as it gets jammed in full open position and the bloody thing overheated and you got red overheat light comes up.
So yes most of the cancers are man made, created by our pollutants and our industry, think about how much asbestos is floating around from years of use of asbestos in car brakes shoes and pads and clutch plates, that dust is still lingering on today despite the use of asbestos is now banned. And other household chemicals, nuclear bomb tests, and so on.
If I see a boiler fitted with an asbestos seal, I would remove it out completely and reseal it with my own home made seal made out of high grade silicone! but Mr Robinson wouldn't know first thing about silicone!
