IP65 garage light switch: Sealing the cable entry points
16 Mar 2005
My garage roof now leaks a bit in heavy rain. So I have bought this type of IP65 external switch to replace the existing standard internal fused light switch in my garage.
https://www.screwfix.com/p/british-...y-weatherproof-outdoor-switch-with-neon/54649
Should have bought the 1-way version really, but it seems I can easily convert it.
A couple of questions:
- I will remove the circular punchouts at the top and bottom of the mounting box. How do I then seal the mounting box? This an obvious place for water ingress, and the holes look rather large.
- The switch does not seem to have a fuse. Is this a common design for external switches -- the mains unit trips instead?
Thanks, I can see how that would be a good seal.
I expected something like this to be supplied with the product...
It doesn't matter. The other way round would.
Why? Just use the bottom ones.
You have bought one that does not have a fuse.
Why does it matter?
Why are you always nit-picking?
I would hazard a guess that EFLI picked a place most people live near and a brand that is half the price of MK. It happens to have a neon, so what?
Just bought a pair of M20 grommets from Wickes.
The cable seals are missing!
Would a few winds of insulation tape suffice to give a decent seal?
EDIT: Found it. It was black rubber ring lodged in the top nut. Nothing like the diagram in the instructions.
Re: Neon. All stock at Wickes had neon.
You can configure the neon operation:
- Neon always ON when power is ON (called Power mode)
- Neon only ON when switch is ON (called Switch mode)
- Neon only ON when switch is OFF (called Locator mode, presumably for finding the switch in the dark)
