Adam_151 said:Let me explain, a DIYer could well be someone who designs complex electronics for a living, if such a person wanted to DIY I'm sure its not beyond them to obtain a copy of BS7671 the OSG, and quite possibly the commentary by paul cook (such might be the mentality of such people) and study things completely and they then may well have a better idea of things than an apprenticeship trained spark who is just of the mentality that its a job, hasn't opened his copy of the regs in the last 5 years, etc.
Or what about the people who write the regs? Or people involved in designing the test instruments you use?, etc, etc
I think as long as the person is practical and can use their hands, with the correct advise a re-wire can be a DIY project.
It was good to read Craftys shed install post because he knows the regs and has posted loads of install solutions based on what he has read. However, when it came to actually doing it to take one example glanding the SWA were not as simple as he thought.
IMO the technical side of a house re-wire is the easy bit and can be learned form books etc, the physical install in the hard part.
For a bit of fun here are few non technical questions for anyone who's not a sparks
1. Roughly how long should the tails be between a back box and light switch/socket outlet?
2. When terminating a socket outlet on a ring do you a) strip the cables back and put them both in the terminals, b) twist the 2 cable together put and then put them in the terminals or c) double then over and then put them in the terminals?
3. Whats the name of the hammer & chisel used to chase a wall?
4. What drill bit would you use to make a hole through joists?
5. Whats the best way to lift a floor board to avoid breaking it?
6. After you have lifted 1 floor board how do you see under the floor to sort out a cable route?
7. If you have to take cable off the side of a roll, how should you do it to stop it kinking?
