Hot water storage, is it better to store LOADS of hot water in a well insulated tank and keep the temperature topped up, or produce the hot water on demand, as and when required?
If the latter then I guess it means you could do away with a storage tank all together and use one of those boiler thingys that heats the water as it goes through it. Downside of this is that you need to be able to utilise "instant heat source" at the flick of a switch. (oil, gas, electric.) Obviously solar (or wood stove) cannot be utilised with ths system, or can it?
So... if you want to use solar (or wood stove) then you need some way of storing the collected energy (heat), and I would guess that would be in the form of a "hot water cylinder", "heatbank", "solar store", call it what you will.
In order to OPTIMISE the storage then the "cylinder" (I'll call it that from now), will have to be sized accordingly. I supposed it would be pointless having a 5 gallon cylinder (don't know of anyone who makes one as small! LOL) as A) the solar panel would have to be relatively small otherwise it would just boil up with a modest amount of sunlight and B) it would store enough heat/volume of hot water to just about wash the pots and no more...
On the other hand... if the solar panels were connected up to a massive 20,000 gallon "cylinder" the heat produced would be "lost" in the 20,000 gallons unless there were acres of solar panels. (Bit like pouring a kettle of boiling water in a lake!, the heat is there but dispersed throughout the lake.)
The compromise would be balancing the stored water size (cylinder size) to the hot water usage, (number of showers, baths, basins, washing machines, dish washers etc) and lifestyle, (is everybody out all day with a mad rush for showers/washing early morning and evenings or can folk get a bath/ shower throughout the day allowing recovery of the cylinder?)), balancing this with solar panel size.
In my mind I think the water usage and lifestyle primarily dictates the cylinder size, this needs matching to the solar panels and if there is no room for the required panels then the cylinder needs re-sizing accordingly? If the tank was too big then the required temperature would not be attained, too small and it may boil up. Does that sound logical?
How do I size the cylinder? Does anybody want a stab at working it out for me please? There is LOADS of roof space for panels albeit facing south/southeast. And the wood stove is rated at 20Kw but would have a relatively short firing time, ie it wouldn't be on all day, just evenings potentially.
I am looking for guidance in determining the size of the cylinder please......
Cheers guys.
Cheers guys.
