So basically you're saying that I'd need cable like a hose pipe to power a measly 300w amp at 3v?
Indeed. Have you ever wondered why power is moved around the national grid at over 100,000 volts, rather than 230V, or even 3V? It's because what matters in terms of the cable is the current flowing through it, regardless of the amount of power being delivered to the load at the end - so the higher the voltage, the lower the current for a given amount of power delivered to the load, hence the small the cable that can be used ...
...Your 300W amp needs 100A at 3V and therefore needs a hosepipe. If it used 300V it would need only 1A, and could use very small cable, and if it used 300,000V it would use only 0.001A and could be fed with a cable you probably couldn't even see!
What I don't get is why would I need cable more than twice as thick to power my bike wheel than my cooker, even though they consume the same amount of power.
Because the cable has no clue as to how much power is being delivered to the load - all it knows is how much current is flowing through it. If it knows that 1A is going through it, it could be delivering 3W to the load if its in a 3V circuit, or 230W to the load if its in a 230V circuit.
The current-carrying capacity of a cable is limited by heating within the cable, which is a functon of the amount of
power disipated in the cable (not in the load). That power dissipated
in the cable is equal to I²R (where I is the current and R the resistance
of the cable). The other issue is that the amount of voltage 'lost' due to the cable is equal to current times the resistance of the cable (and resistance of cable obvioulsy gets smaller as it gets bigger) - and you can accept a larger voltage loss ('drop') in higher voltage cicuits than in low voltage ones. A 'loss' of 2.5V would obvioulsy be disasterous to your 3V amp ('cos the amp would only get the remaining 0.5V), but 2.5V loss in a 230V circuit would hardly have any noticeable effect, since 227.5V would still be 'left' for the load.
Does that help at all?
Kind Regards, John
