Technically no real problem. Brushless DC motor - magnet pole pieces and an inbuilt invertor with direction based on polarity.A synchronous motor that is powered by DC!
I'd call that a self-synchronous motor - it's not synced to any reference outside itself. I suppose if it had an internal Xtal oscillator that would do the trick.Technically no real problem. Brushless DC motor - magnet pole pieces and an inbuilt invertor with direction based on polarity.
Do you mean "... a 220V item"? If so, that would seem to be the most likely explanation.What they have done is to add the invertor to make the total assembly a 12V item, but keep the same motor part number.
I guess it depends what is in the black box in the photo. All other pictures on the internet show the motor with two wires coming out, and thats it. The wire colours change in the op picture to red and black, I had assumed this was because they had to be for dc. If the extra block is not an inverter than of course I'm wrong.Do you mean "... a 220V item"? If so, that would seem to be the most likely explanation.
That was also what I thought/expected, but bernard seems to have indicated that such is not the case. If I understand him correctly, that little black box does not contain an 'inverter' (not that that term, alone, is enough to describe something with a DC output!).I guess it depends what is in the black box in the photo. All other pictures on the internet show the motor with two wires coming out, and thats it. The wire colours change in the op picture to red and black, I had assumed this was because they had to be for dc. If the extra block is not an inverter than of course I'm wrong.
I realise that, so the existing motor obviously runs directly off the mains supply. However, if that one you illustrated (complete with 'black box') is an acceptable 'replacement' for what you currently have, and it really were a 12V motor, then that 'black box' would presumably have to contain something which changed mains voltage into 12V? However, if I understand you correctly, it does not - is that the case (or have you perhaps not yet got one to examine?)?The motor in the unit for repair does not have that black box, just a plug at the end of the wires,
