- Joined
- 3 Nov 2021
- Messages
- 3
- Reaction score
- 0
- Country
I hired an electrician recently to install a new radial circuit to supply a hob. I will have the hob installed at a later date.
I expected the electrician to do something like the following:
I believed this work would constitute a new circuit and therefore it would be notifiable work: not for me to do as I'm not in a registered competent persons scheme.
The electrician, made use of an existing redundant and disconnected 32A MCB in the CU (a shower I had had removed during a bathroom renovation). That and the 32A mains ring MCB are connected to an existing RCCB. I kind of expected this.
The electrician did not provide me with paper work.
I expected an Electrical Installation Certificate because it's a new circuit, but the electrician said it wasn't notifiable because the circuit already existed. If he is correct (and he may very well be, I don't know) then this work is not notifiable as it is not listed in Rule 12(6A) but I believe I should still get a Minor Electrical Installation Works Certificate, right?
So: Two questions:
- Install an RCCB protected 32A MCB in the consumer unit.
- Run about 4 meters of 6mm2 twin and earth (in void behind a skirting board then behind kitchen units)
- Install suitable cooker DP isolation switch (in cupboard next to oven)
So: Two questions:
- Is this a new circuit?
- What paperwork should I have received if any?
