Indeed, although the usual way would be to confirm polarity and cpc continuity live with a simple Zs test. (Although this would be done even if it was a Class II accessory, unless the lighting circuit had no cpc of course.) Where an RCD was installed, it would also be prudent to verify its operation. It could be recorded on the invoice or not, but the testing and verification should still take place regardless.Assuming that some testing was done, e.g. with the switch replacement example that would be at least functional testing, should probably include polarity, and if it's a metal switch definitely cpc continuity, then even if no "certificate" is provided, at the very least the invoice should document what was done.
