Unless of course you have a TT supply.ban-all-sheds said:Necessary? 0%
Having rcd plus 3 core extension must help here surely ? I mean if you cut the cable, contacting the live conductor .. isn't there a good chance that you will have cut and cotacted the earth conductor as well ? Thus removing some if not all danger of current through the person ?brown-nought said:........If you get a L-N short then the fuse/MCB will blow. The RCD will only trip when its earth leak threshold is exceeded.
Plugtop fuse went. The cable action all took place under the mower, so I never saw or heard any fizzpopbang. No RCD trip as there was never an earth fault (2 core cable)pipme said:Has anyone reading, inadvertantly cut the cable under RCD protection, Was it a shock ?
Indeed, as that's the one you're likely to cut through - the integral flex is always too short. AFAIK those rubber 2-pin plugs that you get will go into a 3-pin socket, but I might be wrong.If electric mower, or hedge clipper has just two core cable in it's own short cord, is there any benefit in using 3 core (L.N.E) extension lead ... with of course, RCD, at least at the socket supplying the extension ?
That's the only way it could happen - the only way you could plug an earthed appliance into a cable with one of those rubber connectors would be if someone had replaced the 2-pin with a 3-pin. Ore vice-versa on the appliance.I bought an extension lead reel, in 3 core seems more versatile to me.
Surely the two core type could be used on the wrong appliance ? i.e. One requiring an earth ? Especially if someone changed the 'adapter or socket end'.
