It must be true because Jeremy Clarkson said it is the most ridiculous thing I ever heard in my life!
If an engine is starved of fuel, regardless of it's delivery method, then the engine will stop. That's why fuel exists, to power the engine.
Sorry but you are wrong. If you parked a car on a hill with the ignition switched off,released the brakes (lets forget the the steering lock for the moment) then put it into gear say 4th The engine would start turning at a speed dependant on the gradient, the weight of the car, which gear it was in. and the speed at which the clutch was released.This is without any fuel being introduced. This situation would continue till the compression effect of the engine overcame one of the above conditions and the car would stop. I think that with the documentary evidence we have , we must accept (Clarkson aside) that this feature does exist in all/most modern cars.
In my past life I worked in very heavy commercial vehicle (Crane) manufacture. In the 1970s we fitted these machines with exhaust brakes for down hill speed retardation. When going downhill in gear, the driver would take his feet off the accelerator and clutch, and press a button on the floor with his foot, this would then shut off the fuel to the engine and a flap would practically close the exhaust manifold. Thus in effect turning the engine into a compressor, retarding the cranes progress. On the heavier cranes fitted with the Cummins diesel engine the fuel was cut and a cylinder head mechanism stopped the valves from opperating, this system was dramatically effective as an engine brake
Highlighted in bold is what I said, there is NO FUEL introduced, the engine acts as a brake, and the engine won't work. So how am I wrong if you agree with me?
Engine braking is demonstated when going down a ramp, with the engine running normally, select 1st, don't touch a pedal, the car descends slowly, and doesn't run away, as it uses the engines compression to halt the car..
A highly effective way of stopping a car from running away with faulty brakes when parked is to select a high gear, if the brakes fail, the engine compression holds the car steady.
However, if 2nd is selected, and ignition is on, then a 'bump' start can be achieved, as the ignition components have power.
So why say I'm wrong, when you agree with me?
