Is it worth changing this consumer unit?
If the regulation says "it must meet... 18th"
then the regulation does not describe what to do about non-compliances with the current edition of BS 7671. It just says it must be met.
Perhaps it should, but it doesn't. Does BS7671?
I wonder if this draft has to go to committee stage?
Odd that I only found a draft on the .gov.uk website.
Let us take the biggest example.
Installation does not have non-combustible CU; EICR states C3 for this - improvement recommended - not compulsory according to BS7671.
Does that meet the 18th BS761 for renting purposes?
An up to date plastic consumer unit is interesting. I can't recollect seeing any mention of using them in the actual regs but have read an IET note no need to replace, just check connections for tightness.
That's the $64 million dollar question. A rational regime would accept C3 items in the same way as MOT advisories. We'll see what happens.
The other, possibly even bigger one is properties wired with plastic trunking or surface-clipped cables that don't meet the new requirements for cable support in the event of a fire.
