- Joined
- 23 Aug 2020
- Messages
- 91
- Reaction score
- 0
- Country
Found this (https://www.hse.gov.uk/pubns/indg411.pdf):Unless CDM applies, in which case they do.
Domestic clients: If you are having work done on your own home, or the home of a family member, and it is not in connection with a business, you will be a domestic client. The only responsibility a domestic client has under CDM 2015 is to appoint a principal designer and a principal contractor when there is more than one contractor. However, if you do not do this, (as is common practice) your duties as a domestic client are automatically transferred to the contractor or principal contractor. If you already have a relationship with your designer before the work starts, the designer can take on your duties, provided there is a written agreement between you and the designer to do so.
