D
Deleted member 174758
The brackets need to be on the inside of the drawer, not the outside, and they are used to connect the side to the front, so you can exceed 10mm plate length.Yeah I'll use metal brackets but see my original question, I've only got a depth ifv1 centimetre to work with, the screws would need to be tiny. Is that a problem? Tiny screws will eventually loosen wont they?
This means that they will be visible when you open the drawet
