Did you not read this topic before you hijacked it?IanPlumber said:I have a feeling that i may be a cylinder problem but am unsure.
What is the easiest way of telling if this is the case?
Which goes to show why that's an inconclusive test.So far I have shut off the cold supply from my storage tank to the cylinder and ran the hot taps for a while until the water stopped. The F+E tank did not fill or empty.
It probably says "cylinder with sacrificial anode".It says on a sticker on the side of the cylinder " ???crificial cylinder with anode" (first part of the sticker is missing).
It has a coil. Read the Wiki for other details.Not quite sure how these work inside so if anyone can enlighten me i would appreciate it.
You might have a vent and a cold feed, but there's no such thing as an "expansion pipe".The F+R to the cylinder are 28mm and there is a 22mm pipe from the return going to the F+E tank with the expansion pipe off of that.
You could save yourself some gas/oil then, by fitting more controls when you replace the cylinder.The cylinder does not have a stat as far as i can see and i can't find a zone valve anywhere.
Have you searched the forum for people with the same symptoms? (I mean technical symptoms of the heating system, not the symptom of not reading things for yourself).Please help as i am starting to run out of ideas here.
So, you couldn't diagnose the fault, but you can change an indirect cylinder in 3.5 hours. Pull the other one.Redhotferrari said:...3 and a half hours to change the b****y thing!
That's just another lie.Redhotferrari said:Give me all the bits in boxes on a table and I could build a PC in about 10 minutes
I already knew that it didn't include everything involved in changing a cylinder.Time did not include draining, filling and bleeding system, literally just changing the cylinder.
Let's be sure of one thing - the only person you're fooling is yourself.sorry to mislead you
Naturally.Redhotferrari said:But I would like your expert opinion if you are happy to give it?
In my experience the flow out of most worn out coils isn't dramatic, and the hole isn't large.Woud a hole to small to see still cause this type of problem? if so I am truley amazed.
Should the f&e tank not be higher than the cws tank? At least thats what i was thought.
