- Joined
- 9 Apr 2023
- Messages
- 10
- Reaction score
- 0
- Country
Hi.
Hoping someone can advise.
My downstairs CH system is on 3 loops.
First loop 3 rads,
Second loop 7 rads,
Third loop 3 rads.
All loops return via the main 22mm pipe to the boiler.
However, the second loop also feeds 6 upstairs rads, making a total of 13 rads on that loop. The upstairs rads do get quite hot, but never as hot as the downstairs ones, and they are also very slow to heat up. Maybe 1 to 2 hours, but even then I can still keep my hands on them without burning.
Is the amount of rads on the second loop a problem?
I should say that balancing has improved things, but certainly not cured anything.
It would be quite easy for me to change the upstairs feed onto loop one, which would result in loop one being 9 rads, loop two 7 rads and loop three 3 rads, but I don't want to do this if I'm wasting my time.
The boiler is a recent Baxi platinum 40kw, and the system had a chemical flush when fitted, but not a power flush.
Maybe a solid blockage in the upstairs feed is the cause? Who knows?!
Thanks in advance for any advice.
Cheers,
Gary.
First loop 3 rads,
Second loop 7 rads,
Third loop 3 rads.
Cheers,
Gary.
