Could you point out to us where, in the Permitted Development rules, it specifically states that rendering a dwelling is not P.D?Rendering the dwelling does need planning permission as this would breach the 'materials of a similar appearance' condition in Class A. If you had just painted that would be PD- under Part 2 Class C.
why?Rendering a brick house...
Asking for trouble???
why?
Brick walls are virtually maintenance free.why?
Does it?The second it is rendered it becomes an ongoing maintenance issue.
you refer to cheap modern thin coat renders. as expected.The product
Again , only applies to cheap thin coat through coloured rubbish.less favourable sides become mossy, streaked and mouldy.
where, people like you are obsessed with modern rubbish , not like spain wher they use traditional methods.This is the UK not Spain.
correctly applied render needs no repair. Good for 50 years.pain to repair scar free.
who renders old windows in. new windows have the same lifesspan as correctly applied traditional renderWindows can not be replaced without hassle.
not where i come from.full external wall insulation upgrade
“Rendering a brick house , virtually maintenance free’Brick walls are virtually maintenance free.
See my other post.
I doubt the bricks are crumbling, otherwise the op would've mentioned that.“Rendering a brick house , virtually maintenance free’
Very general. You know nothing about the condition of his existing brickwork, or any other brick house.
I’m back and fore on a site atm actually . early 60’s local authority , All built with the same materials , some with cwt failure some perfectly fine and no indication of why . just is.I doubt the bricks are crumbling, otherwise the op would've mentioned that.
At worse those brick walls need repointing every 80-100 years.
Rendering instead...
You know what I mean if you're a plasterer.
I live in a 1950s former council estate made up of brick houses.I’m back and fore on a site atm actually . early 60’s local authority , All built with the same materials , some with cwt failure some perfectly fine and no indication of why . just is.
Elevations of some houses badly spalled and crumbling , others perfect after over 80 years. just is .
congratulations!!I live in a 1950s former council estate made up of brick houses.
Apart from pointing needing a bit of attention (but not failing yet, no gaps), the bricks are still perfect.
Thank youcongratulations!!
Correct, unlike grubby render.Brick walls are virtually maintenance free.
