Paul said:Thinking about the s plan reverse direction problem, maybe the best thing is to flush two rads at a time, so that the flushing circulation will use the other rad as a route, if you get what I mean, or else the zone valve would have to be taken out of circuit.
Er, I don't follow .
I woz told that the Jetflush has a 3 bar pump but is flow-restricted for some reason. Fernox is 3 bar and unrestrcted. Standard Kamco and Norstrum about 1.4 bar. Kamco do bigger machines but suggest the extra pressure can be a problem on old systems. Only if pumping into a dead end surely.
Simond - why do you say Ferroquest is aggressive? Have you had problems? It isn't acidic like DS-3 or FX-2.
