the tf1 does need a bit of room tbh. You need a bit above to pull the magnet out and a bit below to get something under the drain, or a 1/2" hose connector.
I think those dimension rule out my installing a TF1 in my system then.
The return pipe to my boiler has a vertical drop-down length of only around 11" (280 mm) from the ceiling to an elbow, from which it reverts to the horizontal to pass alongside and around the boiler located in the airing cupboard.
There is no appropriate location in the pipe runs above the ceiling either, so it looks like I'll be installing either the new Spirex MB3 (which I believe could be accommodated in my rather restrictive available space) or nothing!
From the comments in here I am not yet all that convinced that it is worth the effort to install an MB3 in my system though. No-one seems to claim such a wonderful performance from them that they should be seen as "a must-have" that will keep my system clean.
In term of effectiveness, I get the impression that the Spiro only rates as third choice, even though it is well-engineered and has a 20-year warranty. Such a life is of no great value if it doesn't do a very good job of filtering the system, is it? Or am I being too negative and pessimistic perhaps?
but the same water will be going round and round your system for years, I dare say it will go through the filter a hundred times a day, so I think all the particles will get trapped.
Thanks John. In the 6-years+ that my system has been operating, following its upgrading, the F&E tank and pump both seem to have acted very effectively as "filters" for the circulating crud.
Yesterday I removed the F&E tank and gave it a thorough clean-out. My plan now is to keep tabs on these two "filters" over the next few months. If they remain clean I'll not bother installing a genuine filter, but if crud forms again I'll probably fit an MB3.
