Is the plumber telling me fibs?
Well ajohn. Take it from an expert, unless using authentic ballafix (which you will never have seen) they WILL leak when turned once they are a few years old. What is your Gassafe number? Are you WRAS qualified to self certificate on water? Muppet.
I tell you what, pop in to your cylinder cupboard, check your central heating pump. If it's got ballafix type pump valves, give it a quick turn for me then come back & tell me they don't leak.
A little bit of knowledge of plumbing is very dangerous.
I come across idiots like you all the time.
As far as I know ofsted inspections will. Look into or want to see records of any water checking regimes in place at a school
Private schools are technically more at risk or have to be more aware of rules and regs caper as they coukd be sued by parents or who ever
State sector
who u gonna sue? The government?
Good luck with that than :)
All new bathrooms in domestic
Tmv on hot out let ;)
Bath replaced or bath room. Revamped tmv on hot out let
Land Lords in the private sector tread a careful path ;)
Tenants out to sue you at the drop. Of a hat
There was a horrific case. Of a 18 year. Old girl. Who suffered from. Eplietic fits
Went around her mother's hse. For a shower
Collapsed in the cubicle she had a fit
As she fell she knocked the shower hot leaver onto full hot
She was doused with hot water in excess of 60 degrees for 10 mins?
Horrifically scared
Shower was a non thermostatic mixer
Another case district heating in an old people's complex
Old girl went to. Get out of bed fell and got stuck between the bed and radiator
Heating came on and cooked her
She died
A case for low surface temp radiators may be
Remember the immersion heater case that helped bring on the overheat stat. A faulty immersion wouldn't turn off, the plastic tank in the loft softened & burst with 50 gallons of steaming hot water dropping onto an infant below. It can't happen now but there are still loads of the old type out there.
Any hot water should be stored at 60 degs c or above
Or brought up to that temp at some time in a 24 hour period
Particular attention paid to the base of any storage cylinder
Hot water needs to be delivered to a hot tap at a minimum temp with in I think 2 min
Cold water temp. Must not exceed a max temp of I think 20 degs with in a time frame
Temp checks carried out on a reg basis
Flushing regime in place due to un used out let's and stagnation issues
Records kept
Tmvs audited and safety checked at least annually
Kitchen sinks do not neccedsrily. Require tmv protection of a max temp of 41 degs less for small. Children elderly or infirm that's 38 degs max
Thermostatic showers checked for safety shut down
Kitchen sinks in commercial are not designated as hand washing neccedsrily
Cut out redundant dead legs too, as water can stagnate there , and grow the bacteria.
Yep I recall that
Also not helped by a chipboard base to. The cold tank that got wet and Collapsed
Never install a cold tank above a bed Imho.
If I really have to put a MST in, I spread the weight over a wall beneath
Records kept
Who is responsible for carrying out these checks? Do the schools hire someone qualified or can someone with a bit of training do them?
The reason for asking is my boss was saying at the start of this year that these are the checks that need to be done on a regular basis but didn't say who would be doing them. If I'm expected to do them then I want to know what the requirements are and what training is available. I assume the temp one is more than simply sticking a thermometer under a running tap. Regarding the flushing of toilets every one of them is flushed at least 3 times per day by the cleaners doing their rounds and they have to record the location and time.
There are specialist companies who will. Do. An inspection a d make recommendations
You need to. Get a copy of the Hse
Publication the control of legionella bacteria in water systems its very good
There are courses for maintenance personnel. Available
Most companies carry g out inspections will also take water samples for analysis which will. Be checked for bacteria etc
Trained people, either externals or inhouse.
Also, whoever will need to consider that, like many risk assessments, it will change with changing building occupancy ; a full college will probably have few outlets that need recorded flushing, because they will be in continual use. Contrast that with the current situation, where stuff will go unused until the assessor actually flushes it.
Same goes for fire risk assessments; events that would be detected within moments (because there are people about) now will not be , and could become uncontrollable before they are detected.
