You can get wood cutting attachments for 115mm angle grinders on eBay. I have one, and it seems dangerous, but it's very handy from time to time.
http://www.ebay.co.uk/itm/115-MM-SA...Home_Garden_PowerTools_SM&hash=item19d621dc26
ninebob a member on here had a fatal accident with a wood blade in an angle grinder about 4 years ago
http://www.metro.co.uk/news/627085-man-killed-by-improvised-power-tool[/QUOTE]
Hum while I don't condone the use of a wood blade in an angle grinder the article said the angle grinder was only for use in grinding and not cutting. Why then have every angle grinder I have purchased come with at least one cutting disc for either metal or stone and sometimes both?
Definition of grind
verb (past and past participle ground /graʊnd/)
1 [with object] reduce (something) to small particles or powder by crushing it: grind some black pepper over the salad she ground up the rice prior to boiling
sharpen, smooth, or produce (something) by crushing or by friction: power from a waterwheel was used to grind cutlery
operate (a mill or machine) by turning the handle: she was grinding a coffee mill
[no object] (of a mill or machine) work with a crushing action: the old mill was grinding again
2rub or cause to rub together gratingly: [no object]: tectonic plates that inexorably grind against each other [with object]: he keeps me awake at night, grinding his teeth
[with object] press or rub (something) into a surface: she ground a half-smoked cigarette into the ashtray
[no object, with adverbial] move noisily and laboriously: the truck was grinding slowly up the hill
You do not cut with friction. You grind. That's why it's called a grinder, not a saw.
It was Notb665. Whilst Ninebob hasn't been around for a while, I sincerely hope that reports of his death are greatly exaggerated!
Thanks for pointing that one out, used an angle grinder to finish off a few cuts into flooring that the Circular Saw couldn't quite get to not long ago (a "general purpose" blade designed for the grinder), it did feel slightly dangerous at the time (no cutoff trigger, no guard, high speed etc) not to mention the large amount of smoke generated and probably fire risk! Doubt I'll use that again, especially after seeing your post.Notb665. a member on here had a fatal accident with a wood blade in an angle grinder about 2 years ago
name corrected
That is simple rubbish and bares no relationship with the definition of cut. For example scissors cut using a shear force and not friction, are you going to claim that is not cutting?. Anything that separates an object into two cuts, it is the very definition of the word, specifically from the OED
[code:1] separate (something) into two; sever[/code:1]
Scissors cut with a sharp edge, yes, not friction. A 'cutting' disc on a grinder removes material via abrasion.
