Is there a white plastic switched 3 gang that will go straight on the old 4 gang back box?
Mk Double pole are always dearer and as John says no good to you, as no good for 2 way as they switch Live and Neutral.
Check your Mcb for the circuit its likely a 6amp or a 10 amp, so either a 10A or 20A switch will do
A 10Amp tends to have a slightly lighter switching action and usually cheaper than its 20Amp brother.
You say you need 2 way ones, these can also be used as 1 way if needbe,
Mk normal grid switches would fit
3 or 4 Gang both fit the twin size box
and sold in screwfix
You will need an earth at the switch though
https://www.screwfix.com/c/electrical-lighting/grid-wiring/cat830532?brand=mk
82380_P
Personally i think that click cover looks ugly
Varilight also do normal type non grid but in metal finish
https://www.google.com/search?q=3+g...0i22i29i30.15122j0j4&sourceid=chrome&ie=UTF-8
And you can remove the fascia whilst painting. Sorted.
