Or fit a bigger gutter.
But, I guess, you property has been like that for the last 100 years or so! Latest BR's (since last year) require any modifications you make to your property also provide a self contained means of containing your surface water (usually soak away) or you must apply for planning permission. You can’t divert your surface water into a foul drain & then into the public sewer system (unless there is no other option) without permission or allow it to drain onto the public highway, which amounts to the same thing really.Iv'e got a thatched roof which has no gutters, which is normal with thatched roofs, and the water from this runs down the path and into the road.
Exactly; caused by lack of investment from our government(s) & (now) privately owned water authorities on a mostly ancient & increasingly overloaded drainage infrastructure which can no longer cope with the ever increasing density of housing development!I can see the logic, during heavy rainfall the street sewers on my road can't cope.
Amazingly I can remember someone was actually prosecuted for diverting & storing natural rainfall for their own personal use. This was back in the 70's/80’s droughts when many river beds dried up completely & the proven case was that they were stealing a resource that, through natural drainage, would eventually become an asset of the water company. Admittedly, they were refusing to pay water rates (they didn’t need to!) which may have had something to do with the case going to court but, conversely, we could now probably be prosecuted for making sure they get all of it!
The new regulations are primarily concerned with paving over of front gardens & new driveways which causes increased drain off onto the highway thus overloading surface water drainage systems. I’m not conversant with the regs. but would guess they have been drafted such that if you are proposing any works that could result in excessive surface water run off from your property onto the public highway then you will have to make provision to contain it.Richard,
I am thinking of building an extension on this year. Is this a modification that will affect the way that the rainwater is disposed of. Also there a few new houses going up with thatchs round here that are close to the road. I wonder how they are dealing with it.
Stuart
