- Joined
- 13 Jul 2007
- Messages
- 118
- Reaction score
- 0
- Country
I want to knock through from the kitchen into the dining room (like everyone else) but I'm not sure if the wall is load bearing or not.
I've taken thee pics which might help.
Some background....
House is two storey.
Built 1990
All walls are dot n' dab board over breeze block
The reason I'm not sure is because of some conflicting evidence - there is no real load above it other than a stud wall, the length of joist span is only 2 feet longer than the lounge span which is unsupported, yet it is made from breeze block where the other major downstairs wall is hollow stud....?
This is the wall from the dining room side
And from the kitchen side
I removed some of the plaster board to see what was behind
This wall DOES NOT support the stair case, the adjacent one between the lounge and dining room does, as shown here by the ingress of the top of the stairs into the adjacent kitchen wall
The beams run side to side from the kitchen to the dining room, prependicular to the wall, however, they run length ways along the lounge for what it's worth?
Above the wall I want to remove is the hollow stud wall betwen a bedroom and the bath room
However, this is offset by about 12" and not directly above the kitchen wall I want to remove.
If I go into the loft, there is nothing above the bathroom/bedroom wall at all.
So..... the roof or it's beams doesn't go anywhere near the bedroom/bathroom wall which, is not only hollow, empty and light weight, but also offset 12" from the kitchen/dining room wall.
The span of the beams from the kitchen and dining room is approx 16 feet. The span of the same sized (unsupported) beeams accross the lounge is 14 feet - almost the same.
Yet, it's made from breeze block?
So builders, is it a load bearing wall given that nothing structural is above it and the beams spans are alsmost the same between the lounge and dining room?
Oh, I've just done the entire bathroom in travertine tiles and THEY MUST NOT CRACK.....
What do people think?
Some background....
Built 1990
