I am replacing an old open vented central heating system with a condensing boiler. British Gas quoted about £4500 (yeah right) to do the job and a local CORGI plumber about £3,500 - both included replacing the gravity fed mixer shower with one suitable for pumped/mains pressure.
I worked for a plumber when I was a bit younger and have done masses of DIY plumbing since then. I know I can get the whole job done for about £2200 if I do most of the work myself and then get a CORGI plumber in to commission the boiler - basically connect all the pipes to the boiler, set up the boiler, fill the system, test it and certify the installation.
This is the work I plan (and am able) to do before I call the plumber in:
Hang the boiler on the wall
Install the flue through the roof
Install the electrical supply (but not connect to the boiler)
Install the Wireless controller (but not connect to the boiler)
Drain the system
Remove old water tanks and pipes
Powerflush the CH system
Run all the pipes (Mains water, CH flow/return HW output) within about a metre of the new boiler and label them ready for the plumber to connect to the new boiler
Install new shower
In order to route the CH flow/return pipes to the boiler also need to shut down and remove the old boiler.
My question is . . . am I doing anything illegal here? Everything I am doing is in accordance with regulations and manufacturers guidelines with regard to siting the boiler and flue and the rating of the electrical supply. My father is a chartered electrical engineer and he has inspected and verified the electrical work I have done.
Thanks.
Drain the system
Install new shower
Thanks.
