Hello,
Have an Ariston Contract STD 210 cylinder which is 3 years old and needs a new pro tech anode as I noticed the warning light was on the other day and when I inspected it the whole connection has corroded so much that the connection has actually broken off now. According to the part list (http://www.ariston.com/uk/Homeowner/media/files/659_Contract_STD_125_150_210_Protech.pdf) the part I need is 340407 (number 11 on that parts list). It's available in various places online such as: http://www.ebay.co.uk/itm/Ariston-3...arden_Hearing_Cooling_Air&hash=item46242c037a
So that's all fine. Only thing I'm not sure about is that all the ones I can find online have a hex shape in which to screw it in to the mounting in the cylinder whereas the one in my cylinder doesn't have that, it just has 2 flat parts on the purple end of it, here is a picture of mine: https://www.mediafire.com/?ard5mghl43b8ymy
Do I just grab that purple end with a pliers and twist it out? What way will it come out, clockwise or anti?
Also if any one knows as well, how do I know where the dial on an Ariston 340 3kW Immersion Heater Thermostat is at 60 degrees C? It just has a negative and positive but no where in the manuals tell me what that temperature range is and what the temperature is in the middle.. ?
Thanks!
Thanks!
