sorry mate,it did turn into a bit of banter between the sparks on here
the way to do this is to find the last light on the circuit and come from there.run the cable through your spur and off to your new lights.that way all you did was extend the circuit to outside.
right, the rcd debate.you do not need rcd protection for lights outside.some people on here say its not a bad idea to have an rcd and this is probably confusing you.the reason some are saying this is you need to take into account the type of lights/location/cable used.i feel the point bernard green was trying to make(excellent post as always)is that you have extended a circuit outside the equipotential zone(your house)and if there is likely to be any possibility of impact damage,for example if you had a ladder on your shoulder and you were not beingcareful taking it down the alley,could you smash it through a fitting you could possibly be killed.then rcd protection would be a good idea as it would minimise the risk.
in short you need to weigh up the risks and type of installation,but in general doing as per my fist paragraph is the safe and correct way to do it based on the info we have on your installation
