Hairdryer and toaster good example and a good example of why RCD protection is essential in a domestic property.
Like a hairdryer or toaster, for example?When the fuse covers missing on these Wylex units there is plenty of accessible live parts with a small object imagine a curious child with a paperclip.
I don't see how this installation is any more dangerous than a regular consumer unit where cable strain can create a small gap between breakers. In this instance, all the CPDs are in place and it does not appear that the front IP rating has been breached.
All true but, rightly or wrongly, the regs only require IP2X on the front of an enclosure.Cables shouldn't be under strain. Anyway on a modern board the gap between breakers will expose only the mounting rail, the bus-bars will be lower down than the cover cutout and have an internal cover anyway.
Toasters are 'interesting'! With hairdryers, there's usually at least a grill or somesuch which makes them at least IP2X. However, as for toasters, I'm not sure I can remember one in which I couldn't touch the (presumably bare wire?) element with my finger if I were so inclined.Like a hairdryer or toaster, for example?
Alternatively they are good examples of why people should think about WTF they are doing, and closely supervise those who are not capable of such thinking.Hairdryer and toaster good example and a good example of why RCD protection is essential in a domestic property.
So are knife blocks.Toasters are 'interesting'!
Next to my toaster is a knife block containing, inter alia, a cleaver with which I could sever the fingers from one hand with a single blow if I were so inclined.However, as for toasters, I'm not sure I can remember one in which I couldn't touch the (presumably bare wire?) element with my finger if I were so inclined.
My point .... that if toasters were part of the electrical installation, they would have to comply with IP4X on the upper surface. As they are, my finger can enter a hole in the top and touch the (I presume live) element - hence not even IP2X.Your point is?
