Same as the old tap, slow, but OK for what it gets used for - brushing teeth mainly (new tap box states for use with both low & high pressure systems)
ps. as a backup in case I had issues with the isolation valve I closed the gate valve feeding cold water into bottom of hot cylinder but hot water continued to flow from taps and I could hear the cold tank refilling in the loft so guess its broken, only had it replaced about a year ago I think
