In USA from what we are lead to believe you have a number of systems never used in UK.
We use 230v derived from a three phase system which always includes a neutral.
However you use split phase, and hot wire 110v systems and as a result the requirement are likely very different as far as isolation is concerned.
I think you would be far better finding a USA forum to ask your questions as we could easy give you wrong answers here because of different systems.
We have single, twin, triple, and quadruple isolators. First two used on single phase and last two on three phase. We have two main earthing systems one combines the neutral and earth in part of the system and as a result we don't in theory need to switch the neutral with an isolator. But the other system uses earth rods and here there may be big difference between earth and neutral so we do need to switch the neutral.
Since you use a split phase system it is unlikely you could use single isolators and likely both twin and triple are used with your system on single phase.
Also you tend to use more transformers than us yours being pole mounted where we tend to use building to house them so likely the earth system is not as good. Also you country tends to be dryer so that will also effect the earth.
So I would ask your question on a USA forum.
