Hi john, about 6,2 from the floor
Do you mean 6 feet 2 inches, aka about 1.88m? If so, that's pretty low, and easily touched by someone in the bath. More to the point, if it's above the bath and at that height it will be in 'zone 1' of the bathroom, and you would need to see if the instructions of your new (mains voltage) fan say that it is suitable/safe for installation in such a location. Sorry to say this, but it quite probably isn't, and that could well explain why there was a 12V fan there previously - so that you may not be able to find a mains voltage fan that can be safely installed in such a position.Hi john, about 6,2 from the floor
Presumably I should be measuring in ac....... Have I made a fatal mistake!!?
Others may have other thoughts.
No, not this time. But next?Have I made a fatal mistake!!?
It does. The OP therefore doesn't have that problem.The MI states the fan is suitable for zones 1 and 2.
That is obviously true. However, whilst 12V is 12V, 12V is not 16.5V which is what the OP was measuring. It's quite probable that such is the no load (minimal load) output of the ("12V") device, but I suppose it's also possible that it has become ill.12V is 12V. So as long as any replacement fan draws no more current than the old one, and thus does not overload the transformer, it will be fine.
No idea, but that info should be on the thing somewherethat doesn't really help? how much current does the old fan draw? (nuaire genie-h)
if so how much does this one draw?
http://www.screwfix.com/p/xpelair-lv100t-w-low-voltage-bathroom-fan-with-timer/78156[/QUOTE]
So just over 1A
There might be another reason.That is obviously true. However, whilst 12V is 12V, 12V is not 16.5V which is what the OP was measuring. It's quite probable that such is the no load (minimal load) output of the ("12V") device, but I suppose it's also possible that it has become ill.
