Hi guys,
I recently been at property that has been empty for 2 years and come across this issue.
When you turn on cold water it runs for about 20 minutes then slows down and then stops. I tried this in the kitchen. The upstairs no water comes out of the tap. I thought it might be a issue with the water tanks in the loft but when going up to look at them, they are not connected so probably have not been in use for many years.
I then turned on and off the stopcock, that has made no difference. I can't see any leaks around the property either.
I noticed Severn Trent put in a water metre outside recently but is not connected yet, so not sure again if they could have been told to turn off the water but then I would expect no water to come in or if there is a leak on their side.
