paulh53 said:...Do You State To The Customer That She/He Will Require The Whole Installation To Be Rewired To The New Wiring Colour Codes???
paulh53 said:I Always Use "Pirelli." Cable, (Where Possible), Even From Erm?"Screwfix"
But Still Suppliers Don't List New Colour Coded Cable Etc, Even Though They Know About The New Colour Codes,
And What Happens After 2006, When You Come To Install An Extra Circuit Comprising The "New Codes", In An Installation With "Old Wiring Codes",
"After 2006 You Cannot Mix The Two Colour Codes"
ban-all-sheds said:paulh53 said:...Do You State To The Customer That She/He Will Require The Whole Installation To Be Rewired To The New Wiring Colour Codes???
wELL, iF wHAT pwl sAID iS tRUE (wHICH sEEMS rEASONABLE):
"There will also be a new Appendix to BS7671:2002 which will explain how to undertake new work in an installation populated by the existing woiring methodology, it is likely that in order for the older wiring to be compliant, all cores will be required to be sleeved in the new colours."
then ALL you HAVE to DO is PUT sleeving OVER the EXISTING cores.
BUT presumably EVEN that WOULD mean A lot OF work, AS taken LITERALLY the NO mixing RULE would MEAN that ONE spur OR one CONVERSION to TWO way SWITCHING etc WOULD mean HAVING to REMOVE every ACCESSORY and SLEEVE the CORES.
paulh53 said:..
But You Missed The Main Point In Your Eagerness To Make Yourself Look Even More Stupid
AdamW said:Oooh, that should make for some better EM shielding too.
Bearing in mind that I have never and almost certainly will never have to deal with 3-phase mains electricity at home (although I do get to use 400Hz 3-phase equipment at work, yay) is all 3-phase mains cable armoured? I had a look on screwfix and they only seem to sell 4 conductor armoured cable for three phase (although it doesn't specify this as its use).
Yes.mildmanneredjanitor said:Do the powers that be give any reason for the colour change?
Don't tell me, for safety reasons - to harmonise with the rest of Europe!
No.Do the words BRITISH EMPIRE mean anything anymore!
Oh come on, you KNOW the answer to that one, don't you...If a man is alone in the woods and no woman is there to here him, is he still wrong?
