Ivory 2 Shower
2 Oct 2009
Berkshire
Wonder if anybody can help. When I switch on the shower the power cuts to the shower but doesn't trip the main fuse in the central fuse board. The neon on the pull cord also goes out. I have bypassed the pull cord and the problem still happens
:cry:
I can turn the power on and off using the trip in the consumer unit, so I dont think there's any problems there - should I be replacing the shower unit or is there a way to test where the problem lies - perhaps a common fault. Thanks for suggestions so far.
does the shower work when you bypassed the pullcord ?
you said when you bypassed the pullcord and problem still happens.
then you say I can turn the power on and off using the trip in the consumer unit.
pullcord is bypassed so its not the pullcord.
is their power getting to shower ?
is the power going dead when shower turned on ?
if both are yes then check the live,neutral in the consumer box.
and check both connections in the shower unit.
don't think is not an answer.
now do what i said.
showers pull alot of power and can have a live connection etc.
soon as a load is put on the cable with a bad connection it can arc etc and power is lost.
I see. Yes, answers to both are yes. How do I check the live, neutral in the consumer unit? Couldn't see anything obvious
Just to report that I checked consumer unit and traced to pull cord switch - no probs. Concluded that it must be poor connection in switch (scorch marks evident) Trimmed back supply and load wires, replaced pull cord and everything working now.
Thanks to seco services for invaluable support
