ok
which i thought was checked when i first mentioned it.I then proceeded to double check the connections in the pull cord fuse box where I notiticed that the blue wire was all burnt and blackend and rather slack.
wired the wrong way round.It's worth noting that the shower has been working A1 for past 4 years, although the pull cord fuse box neon is always on, regardless whether it is set to on or off.
I've noticed that the cable used is heavy duty 3 core (Blue, Brown, Earth) each wire connects to the corresponding colour in the shower unit. Any ideas before progressing further?
(thats a bad connection on the mains cable either in the shower unit or more likely the pullcord.)
any ideas on what ?
nope the light is to tell you that the circuit to the shower is on.Is it not that the red neon which is lit all of the time simply indicates that there is a connection with the main ring,
somethings wrong in that switching assembly as said earlier.In relation to the shower, I have discovered that when turning the power setting knob, there is no clunking sound between turns all but the initial turn from and to the nuteral position....
s*d that.I'm using my mobile to post!
okMid-shower stopped whilst adjusting shower head, neon went out.
okReturned knob to neutral to retry - neon ON, turned knob to activate neon OFF - no waterflow.
first i've seen it. looked more like water had been in contact with the terminal.Checked and cleaned all connections (the 'greening' was infact some form of glue carefully put there by Triton)
have you what before you came on here ?Replaced Solenoied and replaced the brown M/S.
what about the brown don't look healthy either.Inspected pullcord, connection appeared inorder, reinspected and discovered Neutral wire blackend and slack. I suspect that this was a consequence of movement during prior inspection.
I am a network engineer working off shore, my god I thought my role was difficult, I take my hat off to you, I would never have though this would have been so complicated.
