Appearing to be female pretty much guarantees a better response on this forum - isn't that why you chose the handle "polly"? If you'd called yourself "meanlandlord" or something, you wouldn't expect a lot of helpful responses.
I will try to charge the expansion vessel to start with, but if I need to make repairs, can I simply ad the generic expansion vessel to the return heating pipe, or do I need to link it with the pressure release valve?
It seems sensible that I can simply add it to the system, but my plumber hit me with the need to link it to the PRV which may not be as easy as I thought.
Yeah I thought so too. It seems logical that the expansion vessel is part of the entire system and therefore could be located anywhere. The PRV is an independant part on this logic.
