Hello,
Eight years ago we had an extension built. While fitting a kitchen unit the joiner drilled through a cable, one of the RCDs tripped and half of the electrics went off.
Luckily the electrician was on site. He had a look at the damage, said it was just nicked, flipped the RCD back on and work carried on. No attempt was made to repair the cable or re-plaster the inspection hole he made. The joiner just hung the kitchen unit over the damaged area of plaster.
At the time I didn't give it much thought because there was so much else going. This was minor to the other issues we were facing.
But now I have started to have a nagging doubt about it. I can't see how the RCD was tripped without some damage occurring to the cable. It can't can it?
So either:
1) One or more of the conductors is completely cut through and I have two radials.
2) No conductor is damaged but some of the copper is exposed.
3) One or more of the conductors have reduced copper and the circuit is not up to spec.
After the extension was finished another electrician did a test of all the new circuits and the new consumer unit and filled in a NICEIC certificate for building control. I have a copy of this certificate.
The certificate gives a separate resistance reading for the three cores of the cable in question. So according to this all three cores have continuity. Also from the L & N readings I have calculated using 7.32mΩ per meter the length of the cable. This also seems about right.
So unless the other electrician falsified the results (they did know each other) then I can rule out number 1).
So that leaves 2) or 3), so how much of an issue is exposed conductor? Conductors are exposed in the socket outlets after all.
Also this circuit has a washing machine and tumble dyer on it, so quite a high load.
So what to do? Take down the kitchen unit and examine it myself? Get a qualified electrician to do a continuity/insulation test?
Or am I worrying for nothing?
Thanks,
Bob
So either:
Thanks,
Bob
