Junction box/fused spur/socket
One is not correct.
Can you seriously not think of a reason for not using the wrong names of things?
English is a rich language, there are lots of ways to say the same thing with different words or phrases. This isn't a purely technical context, its about the relationship between professional and diyer, as is this forum.
Irrelevant. Words mean things.
Yes, but this isn't one of them.
The OP didn't call it a ring main; you did. He might not have realised it is wrong.
Thanks for all advice so far…
So just for clarity, if this junction box serves other sockets on different 2.5 te wires particularly if it looks to spur from a spur, it would be safe to put in and FCU on each spur wire prior to the first socket?
Is there any disadvantage to dropping to 1.5mm TE for the sockets after the FCU or is it potentially preferable to stick with 2.5TE throughout?
Others may disagree but I'd stick with 2.5 for socket wiring. I doubt the current changes will be the last ones the installation sees.
Yes "Ring Main" is often used when "Ring Final" is actually the correct term, for ring main there are two types 1/ wiring out under our roads/streets and 2/ at a generating plant etc. But so long as we know what is actually meant then fair enough. Spur is another one often ill used.
Live is another often used wrongly.
But Hey Ho, in all walks of life words are often used wrongly/
Usually there is terms in common usage, technical terms and legal meanings. Quite often those three are quite different so I feel we need to try and live with that.
Nobody speaks perfik at all times in all ways, but as long as we make ourselves understood and try our best the fair go says I. There are lots of such anomalies
If someone calls a dog a pooch or a mutt or a canine people know it means dog, if you call a dog a cat thats different.
it would be safe to put in an FCU on each spur wire prior to the first socket?
Yes, each FCU will limit the current in the spur wire to, at most, 13A (largest fuse size). At that point I believe you're safe to use 1.5mm T&E for the spur cable.
(I've, pedantically, changed your quote to say "an", not "and")
