G
gasafengineer
I prefer testosterone myself.
that's the one.
if you think its no different to a Biasi then fit Biasi's, doesn't bother me.
its not my favourite boiler and i rarely install them, nor do i have or want a wife. Just pointing out where you had made a mistake for the sake of accuracy in the post. Comparing a vaillant to a biasi is laughable.if you think its no different to a Biasi then fit Biasi's, doesn't bother me.
I don't use either. The parts you mentioned are made for Vaillant, but not by them. The build quality of the Sine's and VCW's are long gone. The electrics were more reliable but most are these days. If it doesn't bother you then there's no need to be touchy. It's your favourite boiler I'm insulting, not your wife.
Why? Properly installed there's no noticeable difference to the consumer. Everyone can claim their electrical parts are bespoke in so far as you can't fit them to another make. Biasi have to be cheap because they're not well known. In the UK fame always counts over substance.
I repair ALOT of boilers, and its all Ive done for the last 12 yrs, working for service companies, manufacturers and now self employed. I can assure you that in terms of reliability Vaillant p1sses all over Biasi. Biasi are cheap becuase they use cheap hydraulics and pcbs. Diverter leaks, seized pumps and pcb failures are common on Biasi boilers. They also try and recover the losses on boiler costs by having ridiculously expensive spares, and charge customers for warranty calls. I wouldnt touch them with a barge pole. You go ahead though. Italians are well known for reliable engineering
Tibbot";p="2036573 said:Later Vaillant diverters don't need maintenance but did have to be re-called when they had epidemic failure rates. As they did for burner seals which resulted in meltdowns, also hoses which resulted in flooding. Then Wilo pumps had to be changed for Grundfos and there is still a problem with flow switches. .
yep...................although Vaillant is all i fit , domestic wise anyhow.
