Thanks for the pic.
I suspect that you've got maybe mixed rising & penetrating damp - damp, cold walls will also attract condensation. Lack of ventilation will also create condensation conditions.
Not knowing if you have solid walls and a solid floor I'd suggest that you remove the skirtings in the affected areas, and then hack off the plaster back to brick to a height of 1m.
Then allow time for the brickwork to dry - if thats possible.
Then use a 3:1 render mix of sand & NH lime to render the bare brickwork.
Use a remedial skim finish.
Dont use any gypsum plaster.
Think about new sand and lime pointing for the bottom bed courses.
Lowering the ground or installing an effective French or Aco drain will also help.
