its not the whole valve you MAY need but the power pack for it.
Search honeywell site for it but you may find it hard to find for sale as not very popular nowadays
I'm sory that I have been banging on a about the pilot, but, in everyones defence, your posts haven't been exactly clear. Not really your fault, it is about terminology.
Anyway, regardless of the worthiness of the t/coouple or gas valve, the pilot should light. It will light with the t/c removed.
You posh the valve button in, and gas flows to the pilot. The pilot lights, and heats the t/c, which generates a small electric current. This energises the electro magnet, which holds open the valve. You let go of the button, which allows gas to flow to the main burner.
So, if you cannot getthe pilot alight initially, then the fault is a blockage, normally the pilot injector. It is possible that the gas valve has a fault disallowing the flow of pilot gas, but unlikeky - unless someone has screwed down the pilot adjusting screw.
One final thought - we have all assumed that the gas is turned on at the boiler isolation.
You would be amazed at how many gas valves i would change in a year on BB's whilst working on council contracts but on this occasion seeing as there is SOME gas at the pilot i would hand the next GI to call a short length of 5 amp fuse wire (as he probably won't have any prickers) and tell him to start with the pilot assembly and take it from there.
Have been ringing round yesterday will try some more numbers today but Saturday not a good day to be calling people to come out for this.[/quote]
When phoning, be careful to explain that out have gas at the pilot but cannot get a flame. If you start telling them that you may need a gas valve, you will put them off. Getting this going is not normally a drama, unless something breaks when being dismantled.
The pilot went out again over night.
I was able to light it this morning with a match whilst holding the start button in, but once that start button is let go - it goes out.
Engineer who got it running on Sat came back again stripped it down and thinks it is the gas valve as no other issue with new thermocouple or the pilot nozzle.
Its died 6 months too early for me as wanted to wait to put the new boiler in at the same time as doing the new extension not sure what to do now.
