As it was probably used as a loft before conversion, there may be insulation under your floorboards. This will be blocking any heat coming up from the lower rooms. Removing it may allow some heat to rise into your room but, you may lose some sound insulation from below.
Definitely heavy lined thermal curtains across the window. That blind will allow heat to escape around all the edges.
