Morning everybody,
We are currently living over in Singapore but have a property in the UK which has a Keston Celsius 25 boiler installed. We received notification from the tenants in the property that have had a plumber out, that the heat exchanger has gone so the entire boiler needs replacing. It turns out that the Celsius 25 is now obeslete and there is no direct replacement for it.
I've spoken with Keston who advised that the Qudos 28 can be installed in it's place, but that the two outlets on the top of the unit need to be switched round as they are on opposite sides to the Celsius 25.
Has anybody got any experience with this. I'm told that Keston boilers aren't particularly good but this one has been in 5years and only needed a PCB replacement about 2years ago which seems pretty good to me.
The other issue is that the Keston unit was installed behind a fitted kitchen unit so whatever we replace it with needs to be similar in size.
We had a quote of £4,000 to replace the unit and make good the kitchen upon completion of the work, as the new unit (Baxi Duo Tech, Valiant Echo Tech) couldn't be sited in the same position as the Celsius 25.
I'm willing to pay whatever we need to to get the work dopne and would love it if somebody could help with this. The property is in Nottingham so any suggestions for local plumbers would also be gratefully received.
Thanks in advance.
Thanks in advance.
