keston c55 fault code ?
Thankyou for your response mr agile
you seem to have thought one step ahead of me and i was just looking up honeywell motorised valves!
heres what i have done btw its a Keston c55 with 2 inputs one hot water and one from central heating
i have connected the input from the heating to the position for hot water and turned on the heating and the system fires up and runs
then i had to mess with the slider on the back of the motorised valve and set it to open for the water to go into the tank
i am slightly woried that there is now no control over the heating water as the central heating will not auto switch off but it will only stay on for 20mins to bath the little ones
i am going to switch the heads on the motorised valves and see if this solves the problem
if it does buy a new motor for the bust one and fit that
if it doesnt then i guess the problem is with the sender unit
does this make sense
ps i would love to start a new thread but am not sure where to put it
thanks nickabanana
Its a bit late now but you put it in "new topic".
You seem to have now understood whats necessary.
Better to just replace whats necessary rather than changing things over.
In many cases its only the motor that has failed and that can be changed on its own on Honeywell units.
Measure resistance and if o/c then its failed.
they can also fail by jamming.
Tony
Thanks Agile i took out the motor and it was goosed.
put a new one in (£10) and the mrs is happy again.
btw i love my six year old keston c55 never let me down till now and that wasn't even its fault
thanks for the help
nickabanana
Keston are being sued because one of their boilers caught fire after their service engineer had been to repair it.
The boiler apparently did damage valued at £150k to two flats.
I wonder how that follows unless it was a wiring fault he introduced. Otherwise random electrical faults on components could happen anytime. If there is a known electrical fault though, they should announce it and do a recall on that part.
There was a tv show last night which had a family who were struck by electrical fires twice in one week. First was a jacuzzi heater - did some damage. Second was a fault in a freezer compressor. Burnt the entire house down. http://www.thenorthernecho.co.uk/news/4842698.Family_return_from_holiday_to_farmhouse_devastation/
If you read the report of the case you will see that it would appear that the combustion chamber might have split or the gasket failed.
It does say the O?H fuse had blown but did not say that it had been replaced. It makes me wonder if he had perhaps just bypassed it?
Tony
