"End of" what? They would certainly be able to point out that the new circuit needed to be (should have been) notified to them, but there is no way that it is within their remit or power to tell the OP what sort of cooking appliance to connect it to!LABC have noticed a new circuit - end of.
That's verey possibly true, and may well be the reason why the OP has been told that he cannot continue to have a gas hob.Gas appliances in internal and/or open plan kitchens have specific ventilation requirements which presumably cannot be met in the OPs alterations.
Agreed, however it may be that the council is guiding the OP to the easiest (best) solution. Much in the same way that "Domestic consumer units MUST be metal" that we often see quoted..That's verey possibly true, and may well be the reason why the OP has been told that he cannot continue to have a gas hob.
However, there's surely no way that LABC can (as has been suggested) tell the OP what sort of electrical hob he has to install, is there?
Kind Regards, John
Possibly. As has been said, it's also possible that LABC merely said that he needed to change to an electric hob, and that it is the OP who has decided that that means (and/or he would prefer) an induction one, rather than any other time.Agreed, however it may be that the council is guiding the OP to the easiest (best) solution.
That's surely different, since having a 'non-combustible' CU is a requirement of the current BS 7671, whereas any sort of electric hob would be perfectly satisfactory (and compliant with all relevant regs etc.) if he can't continue having a gas hob.Much in the same way that "Domestic consumer units MUST be metal" that we often see quoted..
All true. However, the requirements for ventilation in kitchens with gas cooking appliances (as described in detail in the document linked to by flameport) are not excessively demanding, even if the room has no external walls, so I would be surprised if it were not possible to address that (probably fairly easily/cheaply) such that a gas hob could continue to be used? I certainly know of many kitchens, some in relatively recently-built houses, that have gas cooking appliances in their kitchens, so it is certainly not 'impossible'.The easy answer to have the best chance of achieving compliance, including costs etc but other solutions are available. In all things in life it is often the easiest shortest idea that offers the best all round solution much of the time but that does not always preclude other solutions.
As I've just written, that is certainly possible. As for whether or not we will 'ever know', that presumably depends upon what the OP now tells us.I suspect the OP misunderstood what LABC actually said, but we’ll never know
No I didn't. The instruction was very simple and straight forward. I am to put fire doors everywhere and swap my existing dual power cooker for an induction hob because, he said, of fire risk.I suspect the OP misunderstood what LABC actually said, but we’ll never know
As has been said, I doubt that 'fire risk' is the issue - much more likely that, as flameport suggested, it was a matter of ventilation of a room containing a gas cooking appliance. However, as I've said...No I didn't. The instruction was very simple and straight forward. I am to put fire doors everywhere and swap my existing dual power cooker for an induction hob because, he said, of fire risk.
Thanks for your reply John. The thing is - we're selling up and I really can't be bothered arguing with my LABC bloke. I just want this situation sorted, so we can get the sign off and move. BC are insisting on fire doors and an induction hob. So that's what they're going to get. My Sparks got back to me saying : I can't run a 10.8 KW induction hob/cooker on a 10mm cable. It has to be a 16. So sod that. I'm getting a new worktop from Wickes, cutting a hole in it and we're getting a plug & play induction hob to go in it. Same with the elec' oven I now have to buy. I'll get one as cheap as possible to go into a Kitchen oven cabinet.As has been said, I doubt that 'fire risk' is the issue - much more likely that, as flameport suggested, it was a matter of ventilation of a room containing a gas cooking appliance. However, as I've said...
1... It would very probably not be all that difficult to address the ventilation issue and therefore continue using a gas hob.
2... If the ventilation is currently inadequate, and cannot easily be rendered adequate, then that might mean that the best/easiest course would be to change from gas to electric hob - but it would make absolutely no difference what type of electric hob was used,so the lABC could not reasonably insist that it had to be an induction hob.
Kind Regards, John
Fire doors? How many storeys does this house have?Thanks for your reply John. The thing is - we're selling up and I really can't be bothered arguing with my LABC bloke. I just want this situation sorted, so we can get the sign off and move. BC are insisting on fire doors and an induction hob.
In your situation, can understand that pragmatic approach.So that's what they're going to get.
That's nonsense. Ask him if he understands anything about 'diversity'. However ...My Sparks got back to me saying : I can't run a 10.8 KW induction hob/cooker on a 10mm cable. It has to be a 16.
That sounds like a sensible approach, which (one hopes ) BC could hardly complain about. However, as above, do you really need to leave any hob at all when you sell the house?So sod that. I'm getting a new worktop from Wickes, cutting a hole in it and we're getting a plug & play induction hob to go in it. Same with the elec' oven I now have to buy. I'll get one as cheap as possible to go into a Kitchen oven cabinet.
That is absolute nonsense.My Sparks got back to me saying : I can't run a 10.8 KW induction hob/cooker on a 10mm cable. It has to be a 16.
