Hi, we had a leak and replaced our laminate floor with LVT (a lot thinner), now I get draughts from under the kitchen units, no visible gap from standing height but there is a lot of gap there. I am going to use expanding foam to seal between the wall and floor behind the units but should there be a gap? Would sealing the plinths better cause issues behind the kitchen units? I need a middle ground and less draughts please. Is there some product about 18mm wide that fits on the bottom or top of the plinths to create a better seal whilst still allowing airflow and removal if needed?
Or do I have to replace the kick boards?
Thanks.
Thanks.
