Kitchen Spotlights
Just one idea - it's customary to put replies after questions, not before, unless you're in a Two Ronnies "Mastermind" spoof sketch..... ;)
It's because you're touching the lens of the lamp with your fingers when you replace them. The oil? on your fingers affects the coating (or something) and dramatically reduces lamp life. Use rubber gloves, or a cloth or something when putting new bulbs in so your fingers don't touch the lamp.
(maybe)
Total crap. GU10 lamps have the lamp envelope totally enclosed so you cannot get your greasy mitts on the hot bit.
Your advice is good for capsule lamps, but he has GU10s.
I already said that... :rolleyes:
DontDoItYourself";p="1345286 said:
This is interesting, anyone have any further knowledge on this theory?
just a guess, but its probably due to excess heat building around the fittings.
Just extending the guess work, but i would imagine there is an optium temperature range within which the lamps live the longest. As mentioned already on various threads, if too low, the filament can erode. If too high, the filament will be close to melting. If its close to melting, then they will not be very robust, therefore small vibrations from people walking on the floor above may cause the filament to rupture.
This condition is unlikely to be the same for your bathroom lights, vibration unlikely and fittings open to the loft space can dissipate their heat more easily.
