Before I start - I am in Scotland, so Part P does not apply.
I want to fit 5 20w lights under the kithchen wall units. I have 2x 10-60va transformers - but what is the best way to connect them so all the lights are operated by the same switch?
3 lights are in 1 transformer with the other 2 in the other transformer about 4-5m apart.
The lighting circuit is a junction box circuit, so I plan to extend it and add a new junction box.
What's the best approach:
1. run 2 wires from the junction box to each transformer?
2. run 1 wire from junction box to choc box/ connector then a wire to each transformer?
Also planning to use 1.5mm wire throughout (apart from lights to transformer - they come with wire attached)
Any comments appreciated.
