as the white finish exactly matched our units they were discreetly installed, the light is good and homebase had an offer plus a 15% off weekend so all in all it was pretty good.
Installation: run 3amp fcu from available socket, snip the plug off the new lights and wire them into a junction box that's connected to the 'load' of the fcu.
Snipping the plug DOES invalidate the product warranty as riveralt said as it is seen as 'any or all alterations or modifications'.
Plugs are generally viewed as customer replaceable. If you broke one, for example, you'd hardly be expected to return the light to the maker for repair.
Hopefully you'll have no problems, but if you do, and they kick up a fuss, make it clear to them that you'll continue to pursue it, and at some point they'll have to prove that the light itself broke because you removed the plug.
Looks like their calculator only does electricity usage - does not factor in the costs of replacing capsule lamps with a typical manufacturer quoted life of 2000h. (Which means, BTW, that by 2000 hours 50% will have failed).
