Any sort of planed square edge stuff from Wickes will be fine - minimum thickness of around 20mm though really. They also sell it in single lengths. Squint down the length so you can see if its warped.
You'll also get smaller packs of screws there - they won't be Spax but the sizes are the same and they will do fine.
Countersink the drilled holes in your bearer so the screw heads are just below the surface.....you'll probably find they will pull their own heads in anyway. The drilled holes in the bearer should be the same size as the screw shank so the screw will just pass through.
John
John
