Just starting to plan the rewire of my kitchen prior ro plasterers and new kitchen, here's what I intend, if anyone could give any advice that would be great.
Under cupboard lighting - I thought this would be best run up from the floor in conduit to run off a fused spur from the power circuit. I'll terminate the conduit behind the wall cabinets. I guess I'll have to put the fusebox behind something that can be moved to get to it.
Power circuits - for on top of units I thought I would run the power off the ring mains and thereby have it rcd protected due to the presence of water etc up there. For fixed units such as fridge/freezer and washer/dryer I thought I might run them off a separate ring or spur from the non-rcd side, fused connection units so that someone can't stick a plug in and mow the lawn without rcd protection.
Oven - I plan to have a double high level oven (electric), would 6mm T+E be what to expect and where in relation to the housing should I run the conduit and connection box?
Extractor and hob - I planned to power these with fcu's off the power circuits with the conduit running from the floor straight up behind the hob.
Can't think of anything else for now but I am particularly interested in advice regarding where I should site the various fcu's/sockets. Is it advisable to cut holes in the fitted units and site the fcu's on the wall behind or run the cables into the cabinets and fix them to the cabinets themselves?
Many thanks for any advice - I'm sure I'll get there in the end!
JD
JD
